wolfe10
Aug 29, 2014Explorer
GM,
You said you cleaned the RADIATOR. Did you clean the CAC (Charge Air Cooler) from the FRONT?
What was ambient temperature when this occurred?
Was this on flat ground or a grade?
How is water pump belt tension-- it is on a separate V belt from the serpentine belt?
Have you changed the thermostats (Caterpillar calls them regulators)? That would be my next step.
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Sep 03, 2026
