RVhiker's avatar
RVhiker
Catalytic Heater Install
I'm going to be installing a Wave 8 catalytic heater in my fifth wheel and am aware of concerns and cautions concerning oxygen depletion, moisture condensation, propane leaks, and the need to protect the catalyst pad from dust. The heater will be portable, that is not attached to a wall. I have questions in three areas:
1) I would supply propane to the heater via a flexible hose. I'd like to have a quick connect fitting at each end of the hose. Is there any reason this connection method is not a good idea? Is there one type or brand of quick connect fitting that is best - that is, more durable or less prone to leaking? Is there one type or brand of propane supply hose that is best - more flexible, resistant to damage?
2) Can the heater be moved when it is on? Is there a grab handle on it of some sort?
3) Any vital piece of information about catalytic heaters that I need to know?
Thanks for all replies.
Having RV issues? Connect with others who have been in your shoes.24,294 PostsLatest Activity: Aug 04, 2025
