mockturtle's avatar
mockturtle
Explorer II
Apr 24, 2013
Catalytic heater install
I just bought an Olympian Wave 6 catalytic heater along with the necessary accessories. It's going to remain portable, rather than built in, so I just need a tie-in to the propane line under the stove top. Here's the problem: The local RV service center won't do it and I don't want to attempt it myself. Would a propane company be a better choice than an RV service facility? Where would I find a 'qualified installer'?
  • I will stick solely to the OP's question...
    It makes sense to install a propane shutoff cock valve near the junction of the feed line to the heater. I am very, very touchy about what kind of supply line I use for the heater. Routing the line so it doesn't get in the way is one of my primary objectives. I have had to have custom LPG hoses made up with crimp 90 degree elbow fittings at a hose place in order to make a clean and neat installation.
    Best of fortune with your installation. You're going to love it! The pot bellied stove effect on a cold day is priceless!
  • Oylmpian CAT heaters require minimal venting. The first RV I had one in was so leaking I didn't bother. (an ET-8100, electronic ignition with thermostat, I don't think they make it any more)
    Do they not want to install something you didn't buy from them, or is it putting the heater in any rig?
    I would not think a propane firm is the right choice. There are many (MANY) RV services places in the area, even a few mobile ones. I'd keep looking.
  • ...and if you plan on using it inside how do you plan on venting for the heater?
Having RV issues? Connect with others who have been in your shoes.24,283 PostsLatest Activity: Jul 17, 2025
