I will be replacing all the painted steel exterior on my Cottage with stainless steel screws. What do you suggest for the caulking that goes on each screw?
What are the stainless screws screwing into? If they are going into another metal, you will get corrosion and then have a real problem. Stainless screws aren't the answer to everything. A product like Tef Gel should be used
Having RV issues? Connect with others who have been in your shoes.24,373 PostsLatest Activity: Apr 02, 2026
