kerrlakeRoo
Jun 12, 2017Explorer
RVcrazy wrote:
Our RV is in the shop for some changes. Suddenly, the inverter is no longer charging the batteries. Both batteries & inverter were fine... Ideas as to cause? Will the batteries be OK with a new inverter, or are they toast now too? Thanks!
Inverter? or Converter?
Converter is the built in unit that uses 120 Volt AC power to charge the batteries. Inverter is usually an add on unit that makes 120 Volt AC power from the batteries.
If your Converter is bad, yes the batteries will eventually go dead and while they may be dmaged it isnt necessarily fatal.
As with almost everything 12 volt power connected, check the grounds first, a bad ground anywhere can stop everything from working.
Having RV issues? Connect with others who have been in your shoes.24,414 PostsLatest Activity: Sep 21, 2026
