BoatCop
Jan 25, 2014Explorer
OK. I've answered my own question. Rather than delete this thread, I'll post my solution in case anyone else has the same issue.
I disconnected the black wire from the MH red wire and ran a jumper from the black wire on the alarm to a known ground. The alarm now works and opens the solenoid as designed.
Apparently the CCI unit worked without a dedicated ground.
Now all I have to do is figure out how to run a ground wire into the space behind the alarm.
Edit: In my Southwind, the gas alarm is directly across from the main power panel just above floor level. Rather than trying to find a run for the ground underneath the coach, I pulled up the carpet, drilled a hole at floor level into the compartment where the alarm is mounted into and also into the power compartment. Ran the ground wire through the holes, under the carpet from the alarm to a ground on the power panel.
Re-tacked the carpet and tested everything.
Works as designed and all is good. Just had to think it through.
Having RV issues? Connect with others who have been in your shoes.24,369 PostsLatest Activity: Mar 12, 2026
