beemerphile1 wrote:
Naio wrote:
...without a roof vent I have routinely measured 110 degrees at bed height at 10:30am when it is about 60 outside and sunny.
New van already has a vent hole, which is unfortunately nowhere near the bed. I don't think I want to seal up that one and cut another.
Have a window at the bed? Install a fan in the roof, close all windows except the one by the bed, run the fan on exhaust, and it will pull the outside air thru the window and across the bed.
Yes, that is my plan. I have already installed an open able window by the bed (junkyard, $250 installed). Unfortunately the available window only opens a crack, not enough to accommodate SoundGuy's excellent fan
