I can reach the switches for my inline roof fans from bed, and the speed controller for the one fan from bed as well.
I force feed a 4 inch aperture with 2 inline counterrotating 120Mm fans through a step down ring, 4.75 to 4.0 inches.
One fan is a speed adjustable silverstone fm121, the other is an open frame Artic cool which rotates the opposite direction and blows into the silverstone, if I have it switched on. The Artic cool fan quietens the silverstone down a lot at higher rpms, and also increases airflow a lot.
The silverstone fan has a remote potentiometer for speed control. i just extended the wires to a spot I can reach from my bed or my 3rd chair.
If you have a bigger roof aperture, look into the silverstone fm 181 fan which is about 7 inches square.
https://www.amazon.com/SilverStone-performance-speed-FM181-Silver/dp/B002M78L0AIt is practically silent at lowest speed and draws 0.09 amps and it still quiet at max speed and ~ 150CFM. It only draw 0.29 amps at max speed which I find impressive.
This is a fraction of the airflow of a fantastik fan at high speed, but also a fraction of the amperage and noise.
Silverstone has a significantly more powerful AP182 fan, but it is too sensitive to battery charging voltages at max speed. The hub gets stinky plastic hot. It draws 1.3 amps at max speed, but only 0.05a at slowest speed. I limited mine to 11 volts after the initial stinky plastic episode, and got about 18 months from it before something on circuit board gave up the magic blue smoke in my salt air environment. I now use the cheaper FM181 and rarely miss the more powerful flow of the AP182.
Together I estimate my roof fans on highest speed can move 140CFM. I have the fm181 as an intake fan in a side window. If I have all my fans and my reflectix window shades up, I can hang out in my van in direct sun as the interior temperature remains cooler until about noon then is about the same as ambient temperature until about 4 and then when ambients drop the interior can be slightly hotter than ambient for an hour or two.
No way would I be without a powered exhaust vent on the ceiling.
I will at some point be replacing the 7+ year old silverstone fm121 on my ceiling with a Noctua 3000 rpm industrial fan, whose speed I will control by the 4th PWM wire. It should be able to fight the restriction of my mushroom vent above it better than the silverstone fm121.
My mushroom vent is a 4" Nicro marine style vent I purchased in june 2001. It had a small solar panel and C size nicad battery, and moved 1000 cubic feet per hour. The fan motor and battery have been removed from it in an attempt to remove restrictions to airflow from the much more powerful computer fans.
No worries about rain with this vent.
Here is a mushroom vent:
https://www.vetus.com/ventilation/deck-ventilators/vetus-mushroom-ventilator-dartagn1-ss-incl-plastic-trim-ring.htmlHere is the newer version of the mushroom vent i used, but later stripped out the fan motor battery guts to forcefeed with my 12v computer fans instead:
http://www.marinco.com/en/n20704sPretty hard to beat the airflow of a fantastik or maxair fan, but I am happy with my ventilation system in my Van, and not having to worry about rain
