vermilye
May 14, 2013Explorer II
Another solution is to purchase a sheet of theatrical frost. It is designed to spread the light from fixtures with 1000 watt lamps, so heat isn't a problem. There are many different frosts available - I use Rosco 115, available in a 20" X 22" sheet for about $6.00 - $8.00 from your nearest theatrical supplier or on the web from Adorama for around $7.00. Just cut it to fit.
While you will lose some output, they even make colored frosts that can be used to shift over blue LED sources back to warm white.
Having RV issues? Connect with others who have been in your shoes.24,409 PostsLatest Activity: Aug 28, 2026
