chief4vfd
Dec 21, 2013Explorer
No. The under cabinet lights are on the passenger side and the bedroom light is in the rear. The hot water switch is located on the same hallway panel as the slide out switch. Also forgot, the bathroom light is affected as well. The base of the bed has two modules. The top are fuses and the bottom are breakers. I checked them all each time the affected lights went out. But they all seemed fine. I even reset each breaker during the event, but nothing. They eventually came back on a while, then went back out.
Having RV issues? Connect with others who have been in your shoes.24,370 PostsLatest Activity: Mar 16, 2026
