Muddydogs's avatar
Muddydogs
Chainsaw issue
I'm having a problem with my chainsaw leaking bar oil when it's in my pickup. The saw doesn't leak a bit when its setting at home but when it's in the pickup it does. I'm not sure if it's from the heat under the bed cover, the bouncing around or the pressure changes from the altitude? This last trip it leaked enough bar oil to make a mess out of the Cordura bar cover as well as a nice spot on my bed matt. Got out the WD40 and cleaned everything up then cut a slot in an old rubbermaid container I had to set the saw in to try and contain the mess.
Anyone else have this problem with there saw?
Having RV issues? Connect with others who have been in your shoes.24,320 PostsLatest Activity: Sep 20, 2025
