bugdude's avatar
bugdude
champion 2000i bought at costco.
My brother has the above and recently it began to run rough when in high mode. seems like it is cycling between high mode and economy mode.
any ideas on what the problem could be.
  • Drain carb bowl, clean jet.
    Use fresh gas with Seafoam.
    Current "blend" of Ethanol works OK in cars, usually see regular/frequent use.
    However, often Generators sit with little or no use.
    If you can get regular gas w/o ethanol in your area - use it.
    Call Champion Tech line.
    BTW - Besides the yellow ones.....
    I've had the same problem with my Honda AND Yamaha.
  • How old is it? If he had bought it from Sams, do you think this would be happening?
  • Have him call their service number. They are noted for great service, when needed.
  • Now that's the NICE thing about buying something at Costco. I'd let them worry about it.
Having RV issues? Connect with others who have been in your shoes.24,380 PostsLatest Activity: Apr 14, 2026
