Our_Place's avatar
Our_Place
Champion 3100 inverter / generator
Well I got tired of figuring out the best way to convince the wife we have to buy two Honda's to run our 15000 BTU AC unit, so I purchased a new Champion 3100 inverter. Cost the same as one Honda and it will start and run a 15000 btu AC. Super quiet and I like the fact that it idles with no load on it. It's light (83 lbs.) and fits in our storage compartment. There, problem solved!!
  • Ron3rd's avatar
    Ron3rd
    Explorer III
    Good job Our Place. Seems like Champion puts out a good product.
  • Well I got a chance to use it today and all I can say is, WOW!! It is truly impressive. I started it up and the first thing I noticed is how quiet it is. You can talk normal around it and with the "idle down" switch turned on it's even quieter still. It will run almost everything in my camper without kicking the idle up, microwave and AC I would not try with the switch on. With the switch off and running full speed it kicks off the AC without delay! and with the unit running right outside by the slideout you can not hear it running with the AC on and the fan blowing. I feel like I spent my money wisely as this will be a welcome addition to our camping family!!
  • Ron3rd's avatar
    Ron3rd
    Explorer III
    Never owned a Champion but from what I've read here they seem to be a very good value. Seems like everybody loves 'em.
  • Be sure to turn the economy switch off when running the AC. Failing to to so can damage your generator. (happened to my neihbor)It probably isn't very good for your AC unit either. The owners manual for my Yamahas highly recommend shutting off the econo switch when operating high load devices I am sure it is the same for the Champion.
  • I think that will be my next purchase also. And If it is not quite when running the air then you just crank up the radio louder. :)
  • Our Place wrote:
    purchased a new Champion 3100 inverter..Super quiet !
    If it's super quiet when running your air, kudos.
Having RV issues? Connect with others who have been in your shoes.24,412 PostsLatest Activity: Oct 16, 2022
