NinerBikes
May 18, 2015Explorer
SoundGuy wrote:scott1k wrote:
I may not have been detailed or clear enough in my orginal post. I did not turn off the inverter and I have no idea if my AC has a hard start capacitor.
Converter, not inverter.
To see if your A/C is equipped with a hard start cap just remove the top shroud and look. ;)
Here are 4 pics of a Supco SPP6 I just added to my own Dometic Brisk II.Ambient temp was approx 73 degrees. Once the AC was on and I had the lights on, fridges on,etc. I left the AC fan running but turned off the compressor. I then turned it back on. The generator stumbled for a brief moment but smoothed right out. I did it 2-3 more times with the same result. Quite frankly, I never expect to put that kind of load on it.
Wait 'til ambient temp is in the 90s, throw in some elevation, then you'll know what a heavy load really is. :E
Ordered one Suppco SPP6 today for my Dometic, hope it helps save the windings.
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Sep 03, 2026
