otrfun
May 20, 2015Explorer II
Lantley wrote:Operating with the Economy mode off increases the generator's wear & tear, sound level, fuel consumption, and decreases your fun factor when you're camping. Once you've experienced (in the realworld) the benefits of running your generator with the Economy mode on--especially for long periods of time, the last thing you want to do is turn it off.pianotuna wrote:
Hi,
I'm not in the least surpized. Eco mode defaults to 1/4 output and it takes a finite amount of time for the engine to "spool up".
Now, if you had a hybrid inverter, you could quite probably run the air conditioner on a single 2k genny.otrfun wrote:
The EU3000iS a distant 3rd. Surprisingly, one EU2000i with the Eco mode off can produce as much, sometimes slightly more, inrush current than an EU3000iS with the Eco mode on.
I'm not sure I understand the whole economy mode logic. If you need full power use full power . If you want less power use economy mode.
Is your thought/complaint economy mode is too economical and saves too much fuel?
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Sep 03, 2026
