otrfun
May 20, 2015Explorer II
Lantley wrote:I agree with you to a point.otrfun wrote:joeyg wrote:I suppose if you tried to operate a 13-15 amp circular saw (inductive load similar to an a/c compressor) in a construction environment, where you're cycling hundreds of times day, that could potentially cause "damage" with the Eco mode on. The constant ramping up and down of engine RPM's (and inrush current) would definitely stress components.
Doesn't it damage the generator to run High demand things, such as AC, with Eco mode ON? I have the Champion 3000i and the manual says NOT to use Eco mode with the AC on.
FWIW, I've run my a/c with a Champion 75531i (Eco mode on) for days at a time with no issues. I always enjoy that little bit of reprieve from the noise when the compressor turns off.
In any case, if it concerns you, and you don't mind the increased wear & tear (higher engine RPM), sound level, and fuel consumption that results from operating a generator with the Eco mode off, then by all means do so.
Given a choice I think I'd trust the manual.
When I'm in a position where I don't believe I fully understand the risks of a given decision I would agree. In these situations "trusting" the manual or other source would make sense.
On the other hand . . .
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Sep 03, 2026
