EldIr wrote:
Like I said, they changed something.  Page 14 of the current manual.
Stopping the Engine
1. Turn off and unplug all electrical loads. Never start
or stop the generator with electrical devices plugged
in or turned on.
2. Let the generator run at no-load for several minutes
to stabilize internal temperatures of the engine and
generator.
3. Turn the Fuel Valve to the “OFF” position.
4. Let the engine run until fuel starvation has stopped
the engine. This usually takes a few minutes.
5. Press the ignition switch to the “OFF” position.
Important:
Always ensure that the Fuel Valve and the
Engine Switch are in the “OFF” position when the engine
is not in use
This is a typo for sure. Call Champion and ask, No one should follow that unless storing for extended period.
