EldIr wrote:
jasult wrote:
To the OP, you have a dirty float needle and seat!
You can still shut down with off switch.
You should follow long term storage instructions as it says.
You have a dirty carb but it did not happen over night.
I suggest using gas stabilizer after cleaning the carb
It was brand new out of the box when the engine filled with gas. First time it was used. Maybe read the posts more closely before offering a definitive answer (with an exclamation point) that is clearly incorrect.
read the post above from Champion support, turning off a machine should not fill it with gas to the point its pouring out the carp. you obviously have a problem
