nowgrn4's avatar
nowgrn4
Champion voltage fluctuation
I snagged a Champion Mod. #46598 3500/4000 genny from TS for $250 on black Friday. With a Craftsman digital meter my voltage varies 12-13 volts every second or so. It will read 113,118,122,126 all in around a seconds time. It does the exact same thing on each 120volt leg when switched over to 240volts or the 30 amp RV plug or regular 120volt plug. The analog meter on the genny stays rock solid on 120 or 240volts when switched.
This is over a 10% fluctuation. I'm afraid to plug anything into it.
Ideas?
