Williebago's avatar
Williebago
Generator voltage and 12V system fluctuations
Recently noticed the 12V lights flickering in our 2003 Dolphin. Used this as an excuse to upgrade the converter to a Boondocker 4 stage unit thinking our old Magnetek was going out. Also replaced our 6 year old coach batteries with a pair of new Trojan T-125's. Still having same issue but a little better overall.
Both of these upgrades were ones I was planning anyway, but now I am focused on the generator. It is an Onan 5500 Marquis Gold gasoline unit. Sounds good when running and does not appear to be surging, but my digital voltage meter is showing a 119 to 122 voltage fluctuation when plugged into a house receptacle. Did not get a reading on the 12V fluctuation, but I am assuming the 3V fluctuation on the 120V output is causing the issue.
What is the most likely cause of erratic voltage on the genset 120V output when it sounds like it is running just fine?
