MEXICOWANDERER
Nov 11, 2016Explorer
With a P.W.M. charging regime it takes a peculiar pulse frequency regime for the power supply to track a voltage source. First eliminate potential spurious loads that can induce pulse induction with the converter. Shut off by pulling fuses one at a time while observing phenomenon. If all circuits prove innocent then load generator or inverter with 1,500 watt minimum load heater. If no change, further searching is up to you.
I do not see why a 5K 50 volt electrolytic capacitor cannot resolve this successfully. It is a 10 minute installation procedure.
Having RV issues? Connect with others who have been in your shoes.24,408 PostsLatest Activity: Aug 20, 2026
