HORSE
PUCKY
I've gone through more WFCO's than most people see.
I've soldered 4AWG directly to the circuit board and connected them to good flooded and AGM batteries and drawn the batteries down to TEN VOLTS via a carbon pile load tester. The WFCO's (note the apostrophe's followed by the letter S)
Immediately rebounded to Thirteen Point Six Volts.
Battery Destroyer for a battery that is cycled. A so-so maintainer that is connected to a power pole princess from day one.
People who do not understand thermodynamics enough to see the advantage of using multiple cooling fins instead of a solid block of aluminum need to switch occupations to the one that has them hanging onto a broom. All the hot stuff at one end, the fan at the other, with transformers and capacitors in between blocking air flow is sooooo telling. The chatter inside the WFCO management ------ is not about the charger, try "Have you wrapped up the 'Smudgly Account'"?
Too many times around the block to get BS'ed
