- StirCrazyModerator
theoldwizard1 wrote:
trail-explorer wrote:
WIth a DC to DC Charger and upgraded cabling, yes.
Here's a few videos from a truck camper owner:
Truck to RV cabling upgrade
Victron Orion DC to DC Charger installation
The upgraded wiring is not necessary if you are using a DC to DC charger. The charger limits the voltage drawn from the vehicle and at the same time boosts any voltage lost in the stock wiring.
yes but this was showen to be at a cost of extra amprage draw on the inlet side. larger wiring did show to reduce the draw on the altanator for the same output. cant remember who posted it but a search should find it.
Steve - afidelExplorer II
philh wrote:
I'm in solar and battery upgrade hell :)
Kind of decided to go with BB battery. Since my rig came with Zamp solar set up, it requires an adapter to use anything other than zamp solar panels.
There's a cheap and easy solution to the zamp plug:
iGreely Solar Panel to SAE Adapter
https://smile.amazon.com/dp/B07K8GMRDJ/ - pianotunaNomad IIIPhilh,
Replace the ends on the Zamp wiring.
As to the battery--I see little reason for BB's prices. - philhExplorer IIII'm in solar and battery upgrade hell :)
Kind of decided to go with BB battery. Since my rig came with Zamp solar set up, it requires an adapter to use anything other than zamp solar panels. - theoldwizard1Explorer II
The upgraded wiring is not necessary if you are using a DC to DC charger. The charger limits the voltage drawn from the vehicle and at the same time boosts any voltage lost in the stock wiring. - theoldwizard1Explorer II
pianotuna wrote:
It is probably best to use a dc to DC charger for two reasons.
1. to raise the voltage to what the Li really wants.
2. to prevent too many amps from being drawn from the alternator.
IMHO, #1 is much more important than #2, but you get both with a DC to DC charger. - LwiddisNavigator"Can a standard truck alternator or heavy duty alternator safely charge a lithium battery. Just curious"
I disconnected charging from the TV. I use solar or an AC to DC charger plugged into the truck's 120 volt system while driving. Generator is the fall back position. NamMedevac 70 wrote:
Yes a truck can charge a trailer battery with no issues.
Can a standard truck alternator or heavy duty alternator safely charge a lithium battery. Just curious- trail-explorerExplorer II
Victron Orion DC to DC Charger installation - pianotunaNomad III
As usual, it depends. Most wiring for house batteries on towable RV's is small--that would limit the flow of current, thus protecting the alternator.
My own alternator is a 2/3 1/3 duty cycle. So in an hour, full output for 20 minutes. I have seen over 70 amps going to flooded house batteries. I do have manual control of the charging in addition to relays. I am adding a dc to DC charger which will boost voltage and limit current.
