donn0128
Nov 28, 2016Explorer II
By brass fitting I assume you mean the check valve on the hot water side?
Did you in fact fill the tank with water prior to lighting it off? Did you verify that water is flowing from the tank? Turn off the water, disconnect the hot side, connect a hose to it, turn on the water and check to be sure you have water flow. Once that is proved reconnect the hot line and verify the valve is in the correct position. With hot water in the tank by changing valve position you should also verify hot water flow.
