CA_Traveler
Nov 28, 2016Explorer III
Are all shower valves turned off as they can cause your problem.
Next cap the bypass line and make sure water is flowing through the tank.
Why do you have only one bypass valve and is it really a bypass valve? I would expect 2 valves so that you can bypass the tank and drain it for the winter.
