ksg5000
Dec 31, 2019Explorer II
Dusty R wrote:larry cad wrote:TurnThePage wrote:dougrainer wrote:Would that plastic be rated for the heat?
DFORD pic looked plastic. You can get a Plastic type extension and do the same thing DFORD has done without using metal. Doug
PVC pipe is used frequently in hot water systems.
NOT PVC but CPVC is rated for both hot and cold water.
Dusty
Recall that you should CPVC rated 80 not std 40 for hot water - not a plumbing guy just something I ran across when doing a rental "fix".
Having RV issues? Connect with others who have been in your shoes.24,409 PostsLatest Activity: Aug 29, 2026
