wolfe10
Jan 02, 2020Explorer
Another good option for removing mineral deposits is to "vacuum then out".
5' of cheap clear vinyl hose. With tank full, but not pressurized remove plug insert hose and start a siphon with it. Move the tank end round the bottom of the tank-- you will see in the clear hose what you are vacuuming out (and when you all you get is clear water.
If it hasn't been done in a couple of years, may have to refill tank and repeat.
