dpgllg
May 11, 2017Explorer
alfredmay wrote:
I have used solid and flex dump valves. I have installed both types myself. I much prefer the solid valve rod because it works better. If it were me I would look into lengthening the rod on the valve you have now. Unscrew the T handle, screw on a long nut and rescrew an extension rod with support. Doing this will be easier than replacing the entire valve.
http://rvsupplies.com/valterra-waste-valve-extension-rod-kit-10-to-12-carded/?gclid=CP_KlN2Y6NMCFYhMDQodSVAMpQ
An extension handle will not work on the galley valve. The valve handle points straight down toward the ground and not out toward the side of the RV.
Thanks!
Dave
