dpgllg
May 13, 2017Explorer
shepfly wrote:
The DRAINMASTER electric valve at 3 inches will bolt in place of your 1 1/2 valve, you may find you already have a 3 inch valve, hooked up to 1 1/2 fitting. You will not be changing the inlet and outlet flanges, just the valve body bolted between them. I looked at both Valterra and Baker electric valves and saw negative comments. Dave
I went back to the Drain Master website and found installation instructions. I would need to purchase a 1.5 inch flange reducer to connect to the 1.5 inch pipe. It uses the same motor regardless of pipe size. I will be looking into these more closely now
Thanks!
Dave
