dpgllg's avatar
dpgllg
Changing fixed dump valve to flexible cable controlled valve
I am looking at this flexible cable controlled dump valve kit from Valterra.
Valterra Flexible cable kit
I have three dump valves on my 5th wheel. Black, grey, and galley. The galley tank in particular is extremely difficult for me to reach to dump the tank. I literally have to crawl under the RV to reach the valve. I have health issues that have made this even more difficult.
Has anyone installed and used these valves?
What is the level of difficulty in installation?
How have they worked out and held up over time?
I really need to find a way to make the process easier. I would run the cables up into my front compartment accessed by the side door opening. I could build a small box to contain the valves there.
Any feedback on the product installation and use will be appreciated.
Thanks!
Dave
  • I have used solid and flex dump valves. I have installed both types myself. I much prefer the solid valve rod because it works better. If it were me I would look into lengthening the rod on the valve you have now. Unscrew the T handle, screw on a long nut and rescrew an extension rod with support. Doing this will be easier than replacing the entire valve.
    http://rvsupplies.com/valterra-waste-valve-extension-rod-kit-10-to-12-carded/?gclid=CP_KlN2Y6NMCFYhMDQodSVAMpQ
Having RV issues? Connect with others who have been in your shoes.24,291 PostsLatest Activity: Jul 29, 2025
