theoldwizard1
Jun 16, 2020Explorer II
jimdmorrison wrote:
Concerning side note: Before I changed the oil, running the generator built up oil pressure, causing it to spray out the next time I opened the dipstick.
There should be little to no pressure inside the crankcase. If there is, the positive crankcase ventilation system is not working.
Could it be that the excess fuel in the oil just raised the oil level ABOVE the fill line ?
The cleanest and simplest way to remove oil from any small engine. Lawnmower oil change using a shop vac
Having RV issues? Connect with others who have been in your shoes.24,384 PostsLatest Activity: May 01, 2026
