jrnymn7's avatar
jrnymn7
Changing the Output Voltage of a Power Supply with a Diode?
So I'm looking at one of these to lower the output voltage of the Turnigy 1080 watt, 60a power supply:
http://www.ebay.ca/itm/RHRG75120-75A-1200V-HyperFast-Diode-TO-247-NEW-/230727070149?pt=LH_DefaultDomain_0&hash=item35b867b1c5
The Turnigy 1080w outputs 13.62 - 18+ volts, and I would like to decrease its overall output range to anything less than 12 volts at the lower end, but no less than 14.8 volts at its upper limit.
Would this rectifier work? Is it a simple matter of installing this in the + lead wire between the power supply and the 12v battery bank?
Thanks!
