Roadpilot
Nov 01, 2014Explorer
It sounds like your power supply may have foldback current limiting versus straight line current limiting, based on your description of the issue. If this is true diodes won't help. Best to use a power supply without holdback limiting.
Straight line limiting is when the current stays essentially constant but the output voltage drops when in current limiting. Holdback limiting is when the voltage and the current get reduced to zero when a short is applied.
Having RV issues? Connect with others who have been in your shoes.24,369 PostsLatest Activity: Mar 12, 2026
