pnichols wrote:
Executive wrote:
Interesting note...we had a flat on the outside dual..22.5 tire. When the guy from Coach Net arrived with the new tire, he positioned a metal ramp under the inside dual, had me pull forward onto it and dismounted the bad tire, installed the new one and aired it up without ever removing the rim....Dennis
Huuuhhh?
So if I'm understanding things correctly... the good inside dual was holding all the weight for a short time while at the same time being mounted on lug bolts with no lug nuts on them?
That doesn't sound like a good/safe practice to me. :h
As the rim wasn't removed, presumably the lug nuts were also not removed. :W
