MEXICOWANDERER
Jan 27, 2016Explorer
Tow charging can be formulated so it makes a lot of sense all the way to needing a straight jacket and rubber room.
What matters 99% of the issue is how many amperes does the tow vehicle make available at the towed vehicle's batteries. If you are attempting to charge a pair of 27's or 3-cell batteries and your vehicle and jumpers can not deliver a big number of amperes at idle, then charging that way is a waste of time and money.
Here's an ideal setup:
A tow vehicle with a HAIRPIN alternator that has an idling potential of total charge acceptance of the batteries. This means a 200 amp or greater hairpin alternator that idles dead slow at 500 engine RPM and can deliver 115 amperes. Not many tow vehicles have factory hairpin alternators - they are relatively new on the scene.
A pair of jumper cables with COPPER wire at least 4 gauge in diameter. At 100 amps 2 gauge is better yet.
Every generator-less motorhome not pulling a toad is every bit as vulnerable as a tow vehicle as far as "getting stranded". At least with a tow vehicle the hood can be raised, which will help to cool any alternator.
A marginal tow vehicle charging system coupled with garbage grade jumper-cables quickly jerks the idea of tow vehicle charging, into the "dumb idea" side of the issue.
For most, a more rational way out would be to get a 1,500 watt generator, and configure a 36-amp Megawatt to do the battery charging. It would make a lot more sense.
Having RV issues? Connect with others who have been in your shoes.24,409 PostsLatest Activity: Aug 29, 2026
