- mcheroExplorerI used the Trick-L-Start on my rig. had it plugged in all winter & kept the chassis bats. up w/o issue.
- accsysExplorerCheck out the Amp-L-Start or it's lesser amperage Trik-L-Start brother for an easy, tried and true, foolproof way of doing what you are considering.
- RJsfishinExplorerYes, you can, but instead of a diode that will cause voltage drop, I put an off/on switch in line
dalehelman wrote:
When I am plugged into shore power my house batteries charge but not my chassis battery. Can I run a charge line from the house batteries to the
chassis battery with a diode in line to prevent discharge of chassis battery when using house batteries?
Having RV issues? Connect with others who have been in your shoes.24,380 PostsLatest Activity: Apr 14, 2026
