vermilye
May 02, 2021Explorer II
I replaced the jumper used to change between lead acid & lithium with a single pole, double throw switch. When in the lithium position, the converter produces 14.6V, fine for charging, but too high for float. My PD converter does not drop the voltage from 14.6V even after a full day of charging.
I can use the switch to change back to lead acid and the Charge Wizard to switch to 13.2V for float after the lithium batteries are full and balanced. When in the lithium position, the Charge Wizard does not change the voltage from 14.6V.
Having RV issues? Connect with others who have been in your shoes.24,411 PostsLatest Activity: Sep 06, 2026
