BFL13
May 01, 2021Explorer II
110v does not go to any "lugs". Your 110v has a black and white wire. black goes to the bottom of one of the circuit breakers and the white goes to the neutral buss. Make sure that circuit breaker has not popped.
You should see 13.8ish at the lugs on the DC panel across the blue pos and white neg output wires from the converter. Battery connected or not.
Your 11.6 is battery voltage to the DC panel and you have no output from the converter, so if the RP fuses are ok that means no 110v in. check that circuit breaker
Having RV issues? Connect with others who have been in your shoes.24,405 PostsLatest Activity: Aug 13, 2026
