BFL13
May 01, 2021Explorer II
ISTR there is a 120v glass fuse on the circuit board to check too.
Check the blue wire and use the metal casing as neg to see if there is any 12v output. if the issue is in the DC panel, that will by-pass the panel for your output check.
You have to be sure the two RP fuses are both good and in tight, before giving up. Replace both and then see.
Having RV issues? Connect with others who have been in your shoes.24,405 PostsLatest Activity: Aug 13, 2026
