CharlesinGA
May 02, 2021Explorer
The batteries will last much longer on the Progressive converter, as it does not cook them. I have installed two in Magnatek/Parallax panels, very easy job. On my Winnebago motorhome, the converter and fridge 120v were on the same breaker so I wirenutted both wires to a short pigtail into the breaker (originally they were both in one wire thimble). The Bigfoot trailer had the converter on its own breaker. By all means install the DC fuse panel, It requires a little wire bending and routing changes as the lugs are in slightly different locations, but you get led warning lights for each fuse to show they are blown and you get a button to control the charge wizard in the converter, plus and LED to show converter status.
USE A 3/8 wrench to hold the square terminal blocks while you tighten the screws so you don't twist the terminals off the printed circuit board.
Charles
Charles
Having RV issues? Connect with others who have been in your shoes.24,406 PostsLatest Activity: Aug 15, 2026
