DaHose wrote:
Hmmmmmmm ...... sounds like running some fresh 4/3 romex from the 30 amp plug to the new charger and then some 4GA wire to the batteries is what needs to happen.
My genny is a 4K Onan, so load shouldn't be an issue. Although, running the charger and the A/C at full bore might be an issue or trip breakers. Maybe a 60 amp
Jose
4/3 romex ?? Where did that come from ?? Maybe you meant 14/2 w/G But I would use 12/2.
And I think I would take it off the ac distribution panel, not the 30 amp plug ! Actually, the 15 amp 14ga circuit feeding the old converter would run a 9260
