Workinprogress
Jun 03, 2019Explorer
Thanks! That is the kind of info that I was looking for. The evidence against the old Magnatek converters was something that I had seen, but not being a electrical guru I was unsure if it was really all that bad or just not the preferred choice for converters..
I will do more investigating and make sure that both converters are in fact in service, but from my minimal investigating this weekend they appear to be... you've got to love buying used stuff and scratching your head trying to figure out what the thought process was behind someone else's modifications.
I will investigate and return with more info before I delete the old Magnatek and wire so that the converter can feed 12v to the coach as it should no matter where the 120v is supplied from.
Having RV issues? Connect with others who have been in your shoes.24,409 PostsLatest Activity: Aug 23, 2026
