BFL13
Jun 05, 2019Explorer II
IMO, toss the 775, keep the 9130 as the converter, and get a 9160 to use as a portable charger for fast charging on generator. You have a Charge Wizard already, so you can use that with either one as needed.
A deck mount converter is a portable charger if it has cut-off jumper cables in its terminals
If you got a second set of 6s to go series parallel like many folks do, you can run the 30 and the 60 at the same time at 14.4v for more amps on the larger bank, assuming you have a big enough generator to run both chargers.
Having RV issues? Connect with others who have been in your shoes.24,409 PostsLatest Activity: Aug 23, 2026
