wa8yxm
Jun 05, 2019Explorer III
Sounds like the "Doorstop" Magnatek had a bad bridge relay in it.
Now the model you have I do not know but the 6300 had two "Sides" if you will. Charger (about 3 amp) and converter (like 40-45 amp; but nasty) it converted `12o VAC into not 12 DC But 12 RMS Rectified DC.. Like I said Nasty.
When not on shore power a relay "Bridged" the two so the battery provided 12 VDC to the house. If that relay was toast.. Well. exactly what you found.
Having RV issues? Connect with others who have been in your shoes.24,409 PostsLatest Activity: Aug 23, 2026
