Need more punch? I have tested this unit model to 148 amps continuous and over 20 hours it did not work up a sweat.
This model has paralleling ports. So if your generator has enough hair, try four units at 600 amps. Or seven (max) for 1,050 amperes output.
It's just as easy to operate as the little bitty 40 amp Meanwell.
TIP: A Honda 3,000 inverter gen would be pressed to operate anything more than one 750 watt Meanwell plus A/C and other normal hotel loads.
Don't let an idiot
BS you into believing it's a
Combined with a
Minus the 16 analog sensors needed plus ten grand in C++
It's that versus a 6th grade education
