doughere
Feb 22, 2014Explorer
I had a POS 2 cycle 1000 watt gen that did just fine with my PD9245 into two GC-2 batteries. Different batteries, but roughly the same capacity.
Assuming you have the pendant(if not, you should get one) you can lower the output if the initial charge is too much for your gen (it would be for only a few minutes on a very low battery). In that my POS did the job with no strain, you should be fine.
Regards,
Doug
Regards,
Doug
Having RV issues? Connect with others who have been in your shoes.24,373 PostsLatest Activity: Apr 02, 2026
