valhalla360
Jun 06, 2022Navigator
engineer40 wrote:
Thank you. Thinking through the scenario, if I'm plugged into shore power (since my batteries are charging), wouldn't anything I use in my camper be using shore power and not the battery bank? So my batteries would be doing nothing except charging?
Or am I thinking about this incorrectly? I'm new to campers.
I'm willing to buy a new/better charger if it would make my camping life easier in some way. Thoughts?
Sounds more like a trickle charger intended to maintain an unused battery (they will self discharge over time even with no loads on them)
2 amps at 12v = 24 watts. Assuming it's running at 2amps 24/7, that's 576 watt-hours per day. (it's not exactly correct as charging is actually at slightly higher voltages but that's offset by not being 100% efficient, etc... but close enough to get a rough idea).
So let's say:
- 3 - 12w light bulbs for 4 hours = 144 watt-hours
- 0.5hr of water pump at 100w = 50watt-hours
- 4hr of furnace fan at 100w = 400 watt hours
That basically gets you to 600watt-hours which means you are using more than you put into the battery.
Do you want to charge your cell phones? Run a 12v fan? If there is an electronic control board on the fridge? Radio/TV? Those will all draw more power...and this is a simple low consumption rig. Does it have electric jacks/stabilizers?
Add an inverter to make coffee or run a microwave and it goes up dramatically.
If you are only out for a single night and you start with a fully charged battery, you can probably make it work if you are careful about power consumption but it's marginal.
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Aug 30, 2026
