engineer40's avatar
engineer40
Charging 6v golf cart batteries?
Hello all! I'm new to campers but have been enjoying learning about my new (used) Viking 10ft popup truck bed camper. It did not come with any house batteries. After some research and looking at my budget for now, I purchased 2 6v golf cart batteries. I have them wired in series for 12v output. They are working as expected.
As far as I can tell, my camper does not automatically recharged the batteries when I'm plugged into shore power. I have a decent work around. There is a house plug in in the same cabinet as I have the batteries. I have a spare smart charger that I plan to wire directly to the battery terminals so it automatically charges them when I plug into shore power. I've been using this battery charger for a few years and it's never overcharged anything.
Since I have 2 6v batteries wired in series I'll need to connect the charger to the positive battery terminal on 1 battery, and to the negative battery terminal on the 2nd battery. I believe that way both batteries are being charged equally at the same time. If I do this, do I have the charger set to 12v/2amp? I'm assuming I do... But my charger also has a setting for 6v/4amp and since the batteries are technically 6v, it has me questioning my thinking here. I appreciate any clarify you all can provide. Thanks!
  • You now have 1 - 12V battery, just in 2 separate boxes. You’re correct in using the 12V setting.
    Now, if it only has a 2A setting, this won’t be of much use while actively using the batteries and trying to maintain a charge.
    Presume your camper doesn’t have a converter from this post and your other post.
    I would find a larger charger.
Having RV issues? Connect with others who have been in your shoes.24,291 PostsLatest Activity: Jul 28, 2025
