Fast charging is important if you have limited generator time like with campground rules on that. If you can get it done in the time allowed using a lower amp size of charger, fine. Getting it down to the least minutes and seconds is not always the priority.
There are lots of ways to do this whole thing, depending on your budget and camping style.
Yes, a good way is to tap into the inverter up front and share its short fat wires.
How to tell if it will do constant amps? (current limited) Ask their tech support, ask on here.
