Joel_T wrote:
What you've suggested was my original thinking. Fixed higher voltage near the batteries for a faster charge using the generator. The WFCO still does the shore power type maintenance when available. The WFCO's plugged in now to get that 100%SOC / 1.275SG back. If 14.8v is good isn't 15v better? :-) And an occasional 15.5 to equalize?
Still want to see something closer to 75a instead of 32.
Yes you still get to twiddle the pot, but not with a chisel.
You won't know if it will do its proper 75 amps constant amps in Bulk until you have a battery bank to test it on. You need the batts at say 1.200 for near 50% and then see how it goes. With short fat wires to the battery and near 120v you could see 76-78 amps who knows? With low 120v you don't get the full amps of course, but it will do some.
BTW, if you do find the unit is not working right, just call Errin and he will look after you. (As long as you don't go around saying PMs are no good etc. :) ) This is all good feedback like they wanted in case there are design issues they can correct.
